I have several Leica\Wild stereo objective lens that I bought from EBay over the years that did not come with a plastic protective case. These lens have the M50, M60, and M65 connection thread on the objectives.
Does anyone know where I can get some used cases to fit these lens?
Has anyone come up with any DIY ways of making cases?
Wanted: Plastic Cases for Leica\Wild M50 M60 M65 Objectives
- MarkSturtevant
Out of curiosity I looked around for some possibilities. Old 35mm slide boxes? One could maybe glue a threaded mount to the lid. Did not see any that would be tall enough. How about the containers that are used to store objective lenses? Those will have the threaded mount already in the lid. Surpisingly I did not see any on eBay that did not also come with a lens. Maybe they are around somewhere else.
It should be easy enough to get centrifuge tubes. The standard polypropylene 50mm conical centrifuge tube seems like a good option, though a bit too tall but still they would work if you can again fix a threaded mount to the inside of the lid. Anyway, here are some: https://www.ebay.com/itm/15ml-or-50-ml- ... Bs2vj3NQAw
Mark Sturtevant
Dept. of Still Waters
- MarkSturtevant
Maybe...
https://www.thorlabs.de/newgrouppage9.c ... p_id=11674
Or https://www.scientificimagingcompany.co ... -lens-case
Or https://benzmicroscope.com/products/mic ... -pack-of-4
I just did a google search for "Objective lens container' and got lots of hits. Those are just a few.
Mark Sturtevant
