rjlittlefield wrote:Lou Jost wrote:Rik, that's not what I was referring to. I'm referring to the problem you have often pointed out, that the aperture of the system should not be in the tube lens. If the tube lens is too slow, it's aperture becomes the controlling aperture, and this will cause aberrations. The aperture should be in the objective Iif the objective is much shorter in focal length than the tube lens, as is usually the case) or between the objective and tube lens.
Understood, but my point was that adding a teleconverter is not likely to
introduce that problem, which is what it sounded like you were worried about.
Yes, if one follows the rule to keep the tube lens wide open, this is a non-issue. I guess what Lou was trying to say is to remind people to keep "tube lens+TC faster than objective".
However, I do know people from photography world, they know the "sweet spot" of a lens, still think to get sharper image, they can just stop down one or two stops from the "sweet spot", but the focal length for tube lens requirement makes them add a TC, but since a TC does not affect the "sweet spot", they think they can still stop down a couple of stops to get sharper image.
So, say a 100mm lens with "sweet spot"of f/4, a couple of stops down make it f/8, adding a 2X TC, now the EA of tube lens as whole is f/16. I think this is what Lou is trying to remind people to avoid. Say a 4x 0.2NA objective on such tube lens system.
My post was meant to say, a TC does reduce EA of tube lens, which now it seems that is what Lou meant, too. However, I do want to correct that a 2X TC causes 2.5 stops loss, it is only 2 stops loss due to optical system, the extra 0.5 stop is due to poor glass which should NOT be included in EA calculation.
Hope this clears things up and believe me, the "sweet spot" scenario does exist in real world.
