For those that might know,
Can this stage be mounted in a vertical position as opposed to flat and work as intended? Also, do you think it can handle the weight of a Nikon Optiphot condenser holder, condenser and stage mounted in that position? I want to mount a X axis stage to a vertical steel column, then adapt a Nikon Optiphot microscope stage arrangement (condenser holder and condenser etc.) to the linear x-axis stage for adjustment purposes (left and right).
https://www.ebay.com/itm/322536525053?ul_noapp=true
-JW:
Newport 411-05s Miniature Ball Bearing Linear Stage
