OM-System Zuiko Macro 38mm vs Canon 35mm Macrophoto at 4x
In RobertOToole's excellent 4X LENS TEST PART 3 - ENLARGING LENSES thread (see http://www.photomacrography.net/forum/v ... hp?t=36199), crisarg asked about the Olympus 38mm Macro lens (38OM). Robert was unable to include it in his list of lenses, so I decided to do a quick test to show how this lens stacks up against the very similar Canon 35mm Macrophoto lens (35MP). I used my HRT2i, and shot both at f/4, which was the optimum for both lenses per previous tests.
My conclusion is that while not quite up to the 35MP, mostly for CA, the 38OM is a solid performer on APS-C at 4x.
Here are some comparison shots, taken of a 1944-D Cent with crops on the Mintmark. First an example of the overall center shot for scale, then the MM detail comparisons:
[/url]
Online
Online
Yes, that's the main difference, though the 38OM is a little less sharp, also possibly because of the CA. Here is a comparison in the corners of the saturated highlight showing CA on the 38OM, 400% crop:crisarg wrote:Awesome, thank you!
Can’t show it, since I’m almost an pure field macro shooter - the situation will be the same on a FF sensor. And in my opinion, the Canon lens has less CA.
Re: OM-System Zuiko Macro 38mm vs Canon 35mm Macrophoto at 4
Thanks so much for this Ray. I was wondering myself so I am glad you took the time. I am sure lots of people will appreciate this, I know I do.ray_parkhurst wrote:
