Increase. The front group 1-2mm.Lou Jost wrote:Karlmera, does the distance between lens groups increase or decrease for digital sensors? If it increases, we could do that modification ourselves by slightly unscrewing the front/rear components of the Makro-Symmar.
Makro-Symmar HM 120mm
Hi Mike,mawyatt wrote: Would be interesting to see how actual lens measured data compares to OEM's published data for various OEMs and lenses. Maybe someone here is/was a recent lens engineer designer that can provide some "inside" information on what actually goes on with the published lens data vs. measured results.
One of the manufacturers, I believe it was Rodenstock, replied to someone online that they expect a lens to perform within 10% of the published MTFs, which are an ideal example.
But I think production sample MTFs are going to be far off from the real world MTF since you have to deal with the camera's sensor glass filter/cover stack. Also I have read that MTF results can easily vary 10% between test runs. The Raw convertor used can make a huge difference in MTF results, the results can vary 10-50% with different RAW convertors so this would cause even more variation in the results.
This would be a good question for Miljenko.
There are some old Lensrentals.com blog posts on this subject of sensor cover glass. One mentions that Nikon bodies having different glass thickness so I this must not make much difference to Nikon but Sony on the other hand supplied LR a custom filter stack from a A7RII to compensate for the lack of cover glass on their test bench to improve their MTF performance. This means Sony optimizes their lens designs for certain camera bodies.Lou Jost wrote:Thanks karlmera. Was this modification done to account for the thickness of the sensor filter pack? If so, I wonder what thickness of filter pack they are designed for.
According to SK Optics in the US, the APO-Digitar N and M were designed for digital backs, so that means PhaseOne.
- enricosavazzi
The thickness of the filter pack is mainly relevant with very fast lenses (f/1.4 or faster). It is not a major concern with an f/5.6 lens, even one designed for high resolution.Lou Jost wrote:Thanks karlmera. Was this modification done to account for the thickness of the sensor filter pack? If so, I wonder what thickness of filter pack they are designed for.
It is more likely that the different spacing between groups is an optimization for a given magnification range. This allows the lens maker to use a single basic lens design, change a single parameter and use the results for a series of lenses that differ from each other in optimal magnification (and possibly just a little in focal length).
The "famous" Jenoptik 60 mm Apo f/4 was reportedly designed for an average thickness of the filter pack of digital cameras at the time of design, noting that the actual thickness may differ by up to a couple of mm in different cameras (with smaller sensors using thicker filter stacks, in part because a thicker stack puts the front surface of the stack farther from the sensor and slightly lessens the negative effects of minute dust particles on this surface). However, CoastalOpt (the original designer/maker) also used to say that the lens would perform optimally within the whole range of filter pack thickness used at the time by large camera manufacturers. This lens, incidentally, uses a fixed rear subassembly (2 elements) and a moving front subassembly (8 elements) to correct aberrations at different magnifications, using the same principle of varying the distance between two subassemblies to optimize at different magnifications.
Some macro lenses use three (or possibly more) moving subassemblies. The Olympus 60 mm f/2.8 macro uses three internal moving subassemblies (3 + 3 + 1 elements, I don't know whether all three subassemblies move on different cams) for focusing and compensating, and two fixed ones (4 + 2 elements) at front and rear of the barrel. The Olympus 30 mm f/3.5 macro uses two moving (3 + 1 elements) and two fixed (2 + 1 elements) subassemblies.
Thanks for the input Enrico.
Check out the full post here on the LensRentals blog:
https://www.lensrentals.com/blog/2014/0 ... it-matter/
Now that you brought up the 60/4 lens (the designer of this lens used to comment here on the forum from time to time BTW) has helped LensRentals with sensor stack info.enricosavazzi wrote:
The "famous" Jenoptik 60 mm Apo f/4 was reportedly designed for an average thickness of the filter pack of digital cameras at the time of design, noting that the actual thickness may differ by up to a couple of mm in different cameras (with smaller sensors using thicker filter stacks,.....
Another excellent post with more sensor stack info:
https://www.lensrentals.com/blog/2014/0 ... ed-lenses/
And another:
And another:
Robert, thanks for the references.
To make quick sense of the overall shape of the graphs...
When the ray cone is perpendicular to the added glass, having the wrong thickness introduces spherical aberration but nothing else. Spherical aberration diminishes as f-number raised to the 4th power, so stopping down is a powerful way of getting rid of it. This is why in the first graph, HERE, the effect of a 4mm stack is still huge at f/1.4 but essentially gone at f/2.8. That 2X increase in f-number turns into a 16X decrease in SA.
But when the ray cone is not perpendicular to the added glass, the added glass adds other aberrations that diminish more slowly. This is why in the second graph, HERE, contrast drops off from center to edge, falling more with steeper angle due to both off-axis distance and exit pupil distance.
The same effects are seen when you're shooting into an aquarium. That's why it's recommended to use a long lens, perpendicular to the glass. See HERE for some discussion and illustration.
RobertOToole wrote:Not sure, but Aperture Mount NK-0 is the device you want in order to use a normal Digitar. This is Schneider's Copal 0 compatible aperture. I don't think they make a Componon style or Makro Iris style barrel versionLou Jost wrote:
So which lens do you think would perform better in a lens stack?
Makro-symmar 1x 120, APO-Digitar Macro 120 1x or APO-Digitar normal 120?
Thats the question
elimoss wrote:Thanks, yes, that does look like the correct mount.RobertOToole wrote:Not sure, but Aperture Mount NK-0 is the device you want in order to use a normal Digitar. This is Schneider's Copal 0 compatible aperture. I don't think they make a Componon style or Makro Iris style barrel versionLou Jost wrote:
Thats the question
