Does Nikon M Plans (210 mm) need any photo eyepiece ?
Marek Mis
Post by Marek Mis »
The tittle of my post is the question.
As far as I know the Nikon M Plans do not need any photo eyepiece but I would like to make sure.
Marek
JohnyM
Post by JohnyM »
No, they dont. They need special extender or epi-illuminator tho, to compensate for thos 50 extra mm. There is one like that on ebay.com atm (not mine):
http://i.ebayimg.com/images/g/KGoAAOSwl ... -l1600.jpg
Post by Chris S. »
Hi Marek,
Are you asking about using the Nikon M Plan objectives on a bellows? If so, you are quite correct--they need no compensating optics. As an example, in the first image here is a bellows rig I use with Nikon M Plan objectives (as well as other finite lenses); in the fifth image down, you see (to the right of other lenses), Nikon MPlan 210mm 20x, 40x, and 60x objectives--all work fine with it.
--Chris
Marek Mis
Post by Marek Mis »
Thank you guys for your prompt replies :)
The objectives will be used with the microscope.
Marek
