Help Identifying Mitutoyo like objective
aidanmoore
Post by aidanmoore »
I recently purchased an eBay microscope with this objective attached. It was not parfocal with the rest of the objectives, so I set up an experiment to find out about the characteristics:
  • M26
    just less than 1mm FOV, so probably 20X
    approx 30mm working distance
    seems distortion free on an Eclipse 200 infinity microscope
It has a HUGE front lens for 20X and an enormous working distance. The last picture shows where I had to place my calibration slide on the condenser to get focus on an E200.
I'm wondering what the possibility is that this is a Mitutoyo Plan Apo 20X?
I know there are other Mitutoyo clones, and the WD is not 20mm like I see on eBay, so I'm a bit perplexed.
Would this objective have any use in a macrophotography application?
Thanks Aidan
Custom Nikon/Thorlabs Microscope Nikon Z7ii ZCAM E4
lonepal
Post by lonepal »
I have a 20X and it reallt looks like it but front cover removed.
Edit : But now I realized that it looks like it is shorter than 20X.
Regards.
Omer
Post by Chris S. »
Omer, if your 20x is the "regular" one--not the SLWD variant proposed by ChrisR--then the SLWD should, in fact be shorter. The Mitutoyo 20x/0.42 that most of us use is 75mm long, excluding threads; the Mituoyo 20x/0.28 SLWD is 64.5mm long, excluding threads. (Reference)
aidanmoore wrote:Would this objective have any use in a macrophotography application?
Possibly. If it is indeed a Mitutoyo 20x/0.28 SLWD (or even a decently-made work-alike), and if it has not been bumped in such a way as to ruin it (this occurs sometimes), then very likely you could use it. The caveat is that a 20x/0.28 will have less resolution than the more commonly used 20x/0.42. In the Mitutoyo specifications referenced above, the 0.28 NA lens is said to resolve down to 1.0 micron; the 0.42 lens, 0.7 micron. As a comparison, this particular 20x objective has a numerical aperture more commonly seen on 10x objectives; so it would resolve about the same level of detail as a typical 10x, but magnify it more.
aidanmoore
Thanks for the information! I just measured the body as per Chris, and it is exactly 64.50mm lens edge to body end before the threads.
So this does indeed look like a Mitutoyo 20x/0.28 SLWD without the front cover. I'll put this at the end of a Nikon 200mm or 105mm lens and see how it performs with a few stacks.
Thanks again for the clues on how to determine the manufacturer/model.
Aidan
