I'm planning ahead for when I'm working again and can afford to spend money on macro photography.
I'm looking to get a couple of wireless flashes (and controller) for off-camera use when focus stacking.
Given all of the issues with Yongnuo, I'm looking at Flashpoint (Adorama branded Godox) flashes, which seem to have a good reputation. This, combined with my good experience with Adorama make this look like the best choice.
These flashes will ONLY be used on manual at low power for focus stacking in a studio environment. I've already got a Sigma flash for ETTL.
Does anyone have a specific recommendation for which Flashpoint flashes and controller I need?
It shouldn't matter, but I'm using a Canon T4i.
Which Flashes for Studio Macro?
I went with the Adorama (Godox) strobes and switched from Yognuno to Adorama speedlights because of RF compatibility with strobes. Haven't used the speedlights for macro work though, but they seem well done and I suspect should be fine for macro use.
I use AC powered strobes for macro because normally I have very large stacks (200~400) sometimes many repeated sessions in a row, and the battery drain for speedlights is too much.
Having neither a microscope objective nor a Stackshot (yet), my stacks should be fewer in number (especially if I override DSLR Controller's suggestions). The flashes should work. I had this combination suggested to me, which seems reasonable:mawyatt wrote:I went with the Adorama (Godox) strobes and switched from Yognuno to Adorama speedlights because of RF compatibility with strobes. Haven't used the speedlights for macro work though, but they seem well done and I suspect should be fine for macro use.
https://www.adorama.com/fplfsmzm.html
https://www.adorama.com/fprrr2t32c.html
I'll be getting two of the flashes.
I don't have any immediate plans for strobes, although I suppose that's something to take into account.mawyatt wrote:I'm sure will work fine. Might want to consider what type of strobes you will be getting and get the compatible RF trigger system that's also compatible with your camera system.
