5 objective turret fitting
My scope has a 3 objective turret, but I use other objectives and I was wondering if the turrets use a standard mount on the type of scope I have (Common monocular type) and if I'd be able to fit a turret with 4 or 5 holes.
Exchanging a fixed turret is rarely possible. There is no standardisation (apart from the objective mounts) and even if you have a replacement turret from the same company, the mechanics are usually not compatible and it's hard to get the turret centered again.
I'd recommend going for a second microscope in the medium term, in particular the small Zeiss microscopes, Standard RA, 16 or 18, with a 5-objective turret!
Regards, Ichty
Regards, Ichty
That is not an option unfortunatelyIchthyophthirius wrote:Hi,
Regards, Ichty
