Hi Gang
Here is a real piece of history; a shot of CORE memory. Yes, long before
semiconductor RAM, ferrite rings were used.
One's and zero's baby, one's and zero's.
core
It is amazing how our technology has grown in the past 40 years
Just think how they got this array to even work as memory
This was just one panel that was made into basically a box and all them were wired together
I gave this one to a friend and asked to borrow it so I can photograph it as I do not have anymore
Indeed!Pizzazz wrote:It is amazing how our technology has grown in the past 40 years
When I was teaching a math class a few years ago, I wrote up a handout that went like this:
The rate calculates out to be 64% per year, doubling every 1.40 years.
The above picture shows representative units of computer memory from 1968 and 2007.
In 1968, magnetic core technology yielded a memory module of 6 KB (yes, 6 thousand bytes) using 5 pounds of material.
In 2007, compact flash silicon technology yielded a memory module of 1 GB (one billion bytes) using 1.6 grams of material.
In terms of memory density (bytes per gram), this represents an improvement of a factor of roughly 2.5x10^8 (250 million).
Assuming that the improvement was exponential, what was the rate?
Unfortunately that module is constructed so that I have never been willing to dismantle it far enough to photograph. The planes of ferrite cores are sandwiched between circuit boards that have many soldered connections holding them in place.
The intact module did make a great classroom prop, though! <insert pumping-iron animated image here >
The technology rate continued, somewhat faster, but the price flattened and rose. http://www.statisticbrain.com/average-h ... ce-of-ram/
Last summer I bought 128GB Micro SD cards for $30, but they've been going higher since.
I suspect the trend may look different at data-centre level.
Core memory
The systems in the early space shuttles used core memory. From what I have read, thery would load it for the takeoff sequence and then replace that software with other software for operations during the flight and re-entry.
Sounds pretty hairy.
