I gave up hunting out new lenses some time back, but! There is one enlarger lens I had always been intrigued with, the CE 30/2.8. I have always wondered how this lens would perform in macro work. Over the last 2-3 years I have kept an infrequent watch out for a suitable example. Finally a near new boxed example came up for sale locally at a price that was reasonable( Euro 80.00). The price I paid might seem steep but some eBay sellers seem to have very optimistic views on what they can sell the lens for. I recall one very badly soiled example being sold with an asking price above US$100.00. I have had the lens for nearly 2 months and I finally got around to testing it over the last few days. I really wasn't expecting much. My previous experience with a Minolta enlarging lens was with the 75/4.5, it was a shocking performer. The CE 30/2.8 was a much better experience.
Note the brown insulation tape is holding a 48mm to 49mm stepping ring in place( this lens doesn't have a filter thread) for mounting a reversing adapter.
It is designed for the 16 mm film format. Mounted normally it is only useful on a MFT camera. The following is a shot taken at just under half sized magnification ( I was quite impressed with this result)
According to the original paper work that came with the lens it is a gauss design( no surprise there) of 6 elements in 5 groups. According to what I found on the internet it is designed to produce enlargements of up to 26X. That apparently doesn't extend to a magnification of 26 times. A flicker post on the lens( which I can't re-find) noted that the lens appeared to work best up to around 8X when reversed. Certainly my experience with the lens confirmed that at about 9X the resolution had deteriorated.
I did some basic tests using both a Euro 10 bank note and a USAF 1951 resolution target for the following shots I used a Sony A7rii with the lens reversed. It comfortably covers a full frame sensor reversed so long as magnification is higher than 3X. From what I could tell the field is flat and corner to corner performance is good.
At 3 Times ( full picture)
At 7.6 Times (center crop)
I didn't expected it to handle CA very well. I tested it using a calibration slide mounted at 45 Degrees The result was better than the Oly 80mm bellows lens, but still wasn't great:
I then tried a stack ( Dmap with Zerene) This photo is a photo-bucket link it is a largish file (and reduced for photo bucket)
The subject is the obverse of a Morgan dollar ( American silver coin). I was quite impressed with the result for such a lens. However when compared with the APO SK 40/F2.8 ( at slightly lower magnification) it is clear it is not brilliant. ( Note the two sstacks were taken a few days apart and I didn't use as much halo suppression with the minolta as I should have. Here is the Sk 40 comparison:
I will be sticking with the SK, but this 30/2.8 might make a cheap alternative for someone on a low budget( if you can find one)
Edit: I decided to couple the lens with an Schneider Kreuznach 210/5.6 enlarger lens. I used a bellows to get the extension necessary for infinity focus with the 210. If I recall correctly this pairing gives a magnification of 7X. This shot is reduced for posting here. The uncompressed tiff shows a much better IQ then I was getting with just extension( but not enough for this lens to move from the "collection" shelf):
Minolta CE 30mm F 2.8
Still learning,
Nice test.
There were (at least) two common ranges of enlarging Rokkors. As you say, the cheaper 4 element (?) ones were horribly ho hum, but the CE ones (all 6 element I think) are pretty good.
The plastic part of the 30mm varies, as though they were made in different factories, but I think the glass is the same. I have one shoved very tightly into a Cokin adapter to reverse it, which grips it perfectly. The ones I have all fit the same ring. I could dig it out if anyone's interested to know the size.
There were shorter (25mm iirc) Rokkor lenses in their miniature cameras, which again from memory were f/2.8 or f/3.5. I bought a cheap "better" camera . Not easy to take the lens out, at all. It didn't look impressive, either. I mean it looked too cheaply made to be any good, and was too hard to test!
Their 25mm/f/2.5 bellows macro is in a different league - not bad at all.
I keep returning to the quoted post. The reason being is that with the 28 mm the optics are very reminiscent of those of the 25mm/2.5 bellows lens. the CE 28mm is a 6 element 5 groups while the 25mm is a 6 element 4 group lens. A comparison between the two lenses would be interestingPau wrote:Sure, this is a Leitz Photar design!ChrisR wrote:Their 25mm/f/2.5 bellows macro is in a different league - not bad at all.
Still learning,
A local expensive second hand camera store has had an example of the Micro Rokkor 25mm F 2.5 sitting on the shelf for a few years. Today I purchased it. I really wanted to see how the CE 30mm measured uup against it. As has been observed in another thread the 25mm seems to produce a more saturated image. It reminds me of the Minolta colors that are typical of the non-macro lenses produced by Minolta. I suspect it is the coating of the lens that is doing this. I am sure the CE rokkor is un-coated, based on my experience that I have to be very careful with the lighting as the CE "flares" easily. Note my version of the micro rokkor is not the X version( Rokkor X was produced for the American market). I leave others to judge. From the full sized images I think the 25mm has the edge ( but not by much)
Still learning,
I take the point on the lighting. I redid the CE 30mm stack with exactly the same lighting as the 25mm and then also did another stack with the SK 40mm. I didn't get the coin placement quite right for the 40mm:
After all the stacking I really can't see much difference. I still think the 40mm is the best but given the price differential the CE 30mm impresses:
top is the ce 30mm, middle is the 25mm, bottom is the SK
Still learning,
Just a quick up date. I changed the lighting I was using and found I could get reasonable shots at 12X magnification.
Still learning,
CE (Color Enlarging) Rokkors are top-of-the-line enlarging lenses made by Minolta. The 2.8/30 and 2.8/50 are 6-elements, 5-groups design, the 5.6/80 is 6-elements, 4-groups. Very sharp and well corrected lenses, every bit as good as any Componon, Rodagon or El-Nikkor. Very underlooked as well.
