The MTF curves I've seen recently for the inspec and other lenses here:
http://www.photomacrography.net/forum/v ... hp?t=29363
are confusing me more than MTF curves usually do.
Is there a standard for stating magnification? What do these mean?
-0.5
0.5
-3.5
Why is it stated in that post that -0.5 is the same as 0.5 and is 1/2x magnification? What does the "-" mean?This is extremely confusing and I finally decided to ask.
I do understand the basics of MTF so don't try to explain frequency or modulation. I just want to know about how the quantities are reported in the graphs, and how to interpret them.
This may be explained in an FAQ but I've read about a dozen explanations of MTF but not a single one talks about negative magnification.
I have further issues with curves I've seen and will probably ask in this thread.
MTF curves
Negative magnification just reflects the fact that the projected image is inverted.
See https://en.wikipedia.org/wiki/Magnification#Photography for some discussion.
Note that the use of negative magnification differs between communities and can be a source of great confusion when reading the other group's papers. For example, in https://en.wikipedia.org/wiki/Numerical_aperture#Working (effective) f-number , the formulas simply give the wrong answers if you plug in positive magnifications instead of the negative ones that are expected.
So does this mean the inspec lens quoted in my link above does not invert the image? Or is Linos/Rodenstock just being inconsistent/sloppy?rjlittlefield wrote:Negative magnification just reflects the fact that the projected image is inverted.
Schneider Kreuznach uses the same system of negative values for ß' (magnification). Now I am curious.rjlittlefield wrote:I'd go with inconsistent/sloppy. It's weird to see such inconsistency in two graphs that look like they came from the same source & setup, but I don't know how else to explain the discrepancy.
