Hello pros.
I tried to take few images with canon 1300d and kit lens 18-55mm reverse held without ring.
I do know that focus is the problem but as i said i held lens myself and i have no tripod.
I wanna know more tips.
Start of the Macrography
Most people's first macro photos look like that.
I recommend that you practice on things that won't run away from you, like screws, coins, etc. When you get your focus, aperture and lighting under control, you'll be surprised at the results you get.
- Get an off camera flash and a cheap flash bracket. Even a cheap manual flash will give you better results when coupled with a diffuser of some sort.
- Do one of the following:
- Get a set of extension tubes with contacts so that you can get closer AND control the aperture on your kit lens.
- Get a used manual prime lens (anywhere between 28mm and 50mm) and a reverse ring that fits the camera body and the filter threads on the lens. This will allow you to easily set the aperture. These days, they practically give away old manual 35mm film lenses. I sometimes use the 50mm manual I bought with my Minolta XG1 back in '81.
- You have minimal depth of field because you're almost certainly shooting wide open. When you can get control of your aperture, use something on the order of f8, for more depth of field. With sufficient lighting, you can go to smaller apertures for even more depth of field.
thanks a lot for advice. am getting reverse ring next week. so will practice with it. i it ok if i use diffuser with camera falsh only?Deanimator wrote:Most people's first macro photos look like that.
The manual lens and reverse ring will probably be the cheapest viable solution.
