Thanks for that, is that what you used to take this?iain wrote:to be honest I would assess the situation and decide whether it was worth the effort - if it was some insect I'd never seen before and there was nothing to aid stability then I'd certainly give it a shot (well, several shots if I'm stacking). I've certainly managed to do this in the past but usually with larger insects which does make things easier. So I would never say it can't be done - just that perhaps some situations may be more challenging than others.davholla wrote:Thanks for that. I took this photo of a fly on a bush and there was NOTHING to support myself on, so your technique wouldn't have worked in that case, if I understand you correctly
Does this work at higher magnifications e.g 4x +?
Works fine at higher magnifications but you'll need to be cautious of not missing a slice or 2 as this tends to require a much wider aperture (and so less dof) per each image
https://www.flickr.com/photos/daddysaur ... ateposted/
What aperture and how many images was it? It is really great, it is similar quality to a photo of much insect.
