Mitu QV 2.5x - any experience?
nielsgeode
Post by nielsgeode »
Any experience with the Mitutoyo QV-HR2.5X?
http://www.mitutoyo.co.uk/vision-measur ... 3/02akt300
An NA of 0.21 at this magnification is a lot and I wonder how it compares to the well-known Mitu 2x NA 0.055. The FoV for "PRO machine" (whatever that may be) suggests very small sensors. Would it cover APS-C and if so, how would corner sharpness be?
Notice the "f=100" engraved on the objective. That's the tube lens length that gives 2.5X. When used with a 200 mm tube lens, like standard for the Mitutoyo M Plan Apo's, this objective would be 5X NA 0.21 instead of NA 0.14 for the M Plan Apo 5X. The larger NA suggests that the QV objective would be sharper at image center. I have no idea how the corners would compare.
If you search Google with the query site:photomacrography.net Mitutoyo QV, you can find some postings about various QV objectives. They will probably add some info, but I don't think that any of them will exactly answer your question.
nielsgeode
rjlittlefield wrote:Notice the "f=100" engraved on the objective. That's the tube lens length that gives 2.5X. When used with a 200 mm tube lens, like standard for the Mitutoyo M Plan Apo's, this objective would be 5X NA 0.21 instead of NA 0.14 for the M Plan Apo 5X. The larger NA suggests that the QV objective would be sharper at image center. I have no idea how the corners would compare.
I've seen the f=100 :) It's not difficult to use a 100mm tube lens instead of a 200mm. Do you think designing it for 100mm instead of 200mm would make it easier to obtain a high NA? Even then, 0.055 vs. 0.21 is a massive difference.
nielsgeode wrote:It's not difficult to use a 100mm tube lens instead of a 200mm.
True, and that's my point. If you stick a Mitutoyo M Plan Apo 5X NA 0.14 on 100 mm tube lens, you get 2.5X NA 0.14. So a pretty fair comparison is NA 0.14 for the M Plan Apo versus 0.21 for the QV, not so massive.
Comparing the QV on 100 mm tube lens at 2.5X, against the M Plan Apo on 200 mm tube lens at 2X, I'm quite sure you'll find that the M Plan Apo has a much wider field. It's the narrow field of the QV that makes it easier to obtain high NA.
Beatsy
Post by Beatsy »
The FoV values given on mitutoyo.co.uk are a bit weird, perhaps cause for concern?
View field: 2.5 x 1.88mm, 1.25 x 0.94mm, 0.41 x 0.31mm (0.62 x 0.47mm)
Remarks:The monitor magnification and field of view values are for the PRO machine.
The FoV of a 5x mitty on 135mm tube lens (3.375x) is 10mm on full frame and 7mm on APS-C. If it were put on a 100mm tube lens it would cover 14.4mm and 9.6mm respectively - but the corners and edges would be vignetted, with poor quality inside that.
The largest FoV quoted above is 2.5mm - so I suspect the FoV is miniscule and can't be pushed like it can with the M Plan APOs.
This all just theorising "out loud" on my part though...
edit: oops, Rik beat me to it
nielsgeode
Peter Lin posted on facebook on his timeline a photo made with the Mitutoyo QV 2.5x NA 0.14. I'm not sure what sensor he used, but it looks like the QV 0.14 does cover at least something like APS-C / M4/3 / ...
Of course it doesn't say anything about the 0.21, however, I would be surprised if there's a massive difference in coverage between the 0.14 and 0.21.
I'll revive this old thread to add that the new version of the QV, with NA=0.21, also has a much longer working distance than the old one that has an NA of 0.14. That is a bit unexpected.
I now have the old version waiting for me in Wisconsin. I think it must be telecentric since it is a measuring objective like the Nikon MM series.
mjkzz
Post by mjkzz »
I have the QV, but I am not sure if it is the HR version.
Yes, it requires 100mm tube (vs 200mm) and yes, it has relatively large NA of 0.14 (compared to others 2.5X). I believe it is an APO lens. Here is a comparison with a Chinese "APO", a regular achromatic 4x. The comparison was done with QV 2.5 on a 135mm f/2.8 lens.
mjkzz
Post by mjkzz »
forgot to mention, I believe the QV series are telecentric and as tested (by me), this QV 2.5x one is indeed telecentric.
Thanks for that info. I'm glad to get confirmation that it is telecentric and behaves like an apo lens. It also has along working distance. This is potentially a really great under-appreciated optic, until now quite inexpensive though hard to find.
dolmadis
Post by dolmadis »
Looking for some information which I have been unable to find on Google.
I have just come across a 2.5x QV with no NA markings.
But it has a serial number or product number D60674.
Is it 0.14 or 0.21?
Thanks if anyone can advise.
BR
John
The QV objectives are fully marked with NA, etc. If yours doesn't have marks, that's suspicious. On mine (NA=0.14) the part # is 02ALA410
harisA
Post by harisA »
mjkzz wrote:I have the QV, but I am not sure if it is the HR version.
Since you own this objective will you please let us know if the mitotuyo qv 2.5x can cover a m4/3 or even a aps-c sensor?
Sure, but it will be several months before I can retrieve it from Wisconsin where it was shipped. I will give a full report after my next trip to the US. I have a bunch of other very cool lenses waiting for me too, including some unique ones that appear not to be known to our community. Lots to report!
dolmadis
Post by dolmadis »
Lou Jost wrote:The QV objectives are fully marked with NA, etc. If yours doesn't have marks, that's suspicious. On mine (NA=0.14) the part # is 02ALA410
Thank you for the warning.
I wonder what the part number is for the NA 0.21?
Just like to mention two others for sale with the D60XXX serial/part number.
http://www.ebay.com/itm/Used-Original-M ... SwoudW4WtR
http://www.ebay.co.uk/itm/Mitutoyo-QV-o ... Sw91NTtkws
So perhaps there are three QV 2.5X legit versions out there.
BR
John
