Have recently acquired the Venus 60 mm macro lense and now slowly experimenting with it. the actual idea is to photographically document the evolution of eggs & larval salamanders once the breeding season starts. In the meantime I am trying to get some practice with the lens 'in the field' ...
Here's a single shot frontal shot of Porcelio scaber, one of our more common woodlice species overhere ( also used the Venus twinflash for this shot). Handheld at 800 ISO.
Now still need to find a way to make the light slightly more softer ;-)
Porcellio scaber by Henk Wallays
[EditAdminCR - the link down a few posts, works]
[EditAdminRJL: replaced link and fixed [img] tags during phpBB3 conversion
Woodlice & Venus 60 mm macro
- MarkSturtevant
Very good, and I am glad to see the Venus macro put to good use. I had read elsewhere here that the twin flash was underpowered, but clearly it is adequate for close-up work.
I suppose the sort of diffuser to use would be a coupe small 'bell' shaped diffusers on the flash heads. You can find similar ones around used for twin flashes that attach to the camera lens. But I too think your diffusion is pretty good as it is.
Mark Sturtevant
Dept. of Still Waters
Thanks for the remarks. I see that my image is no longer displaying too (bizarre) but can apparently not re-edit the thread also.
Anyway, indeed I used the Venus twinflash and as low budget diffuser I added white baking paper in front of both lenses ;-) ...
I continue to experiment further ( offcourse ...). I actually bought the lense to document the development in amphibian eggs & larvae ( salamanders) ... so as the spring & breeding time comes , I want to be 'ready' ;-)
When logged in, you should see an "edit" button at the upper right corner of your posts. Normal users do not have permission to delete a post after it has been replied to, but you can always edit your own posts.Henk Wallays wrote:I see that my image is no longer displaying too (bizarre) but can apparently not re-edit the thread also.
There's something odd with the link to Flickr.
https://flic.kr/p/QQsk3v
does at least show the picture, though I can't get it to display here.
At this moment, the image URL in Henk's post goes to
https://c1.staticflickr.com/1/492/32053 ... 8093_b.jpg .
But by going to https://flic.kr/p/QQsk3v , zooming the image, and asking my browser to Inspect Element, I see a different URL:
https://c1.staticflickr.com/1/492/32053 ... b0ed_b.jpg .
That second URL does display properly here as an image:
Other than this I know nothing, because I'm clueless about how Flickr generates its URLs.
Thanks for the fine help. Hope you don't xpect me to see how Flickr functions ;-) I guess there may be more difficult ways to create a link but possibly quite some more to do it easier too...
Anyway thanks for adding the picture again and indeed now I see the edit button (again) at the time I was replying it din't appear (or I was not fully awake ;-)
