- two diaphragm condenser
Objectives:
- Plan 2.5/0.08 160/-
Plan 4/0.10 160/-
Plan Ph A 10/0.25 160/-
Plan Ph A 40/0.65 160/0.17
Plan Ph A 63/0.80 160/0.17
Plan Oil Iris Ph A 100/1.25 160/0.17
All Reichert.
- one BPK 10x
one Plan 8x
both Reichert
1) Many parts have a five or six digit "Nr." on it them. For example the Plan 2.5/0.08 160/- objective has "Nr. 440 739". Similarly when looking on eBay at Reichert parts many sellers list a similar number with the items and often show this number in one of the photographs. I have found an old Reichert Zetopan catalogue online but the catalogue number and these numbers printed on the parts do not correspond in any way that I can tell. Are the numbers printed Reichert components serial numbers rather than model or catalogue numbers? When buying used parts is there a good way to match the part being sold to known components from old scanned catalogues?
2) In my BPK ocular what do the B, P and K stand for? I think that K means the ocular compensate for the objectives, and the P means planar image, but if any of you can confirm these I would be grateful. What does the B mean?
3) I will be shopping for oculars, either a BPK to match the one I have or a pair of others if I cannot find a matching BPK. There are
many Reichert oculars for sale online. When an ocular is compensating do I have to know what objectives it is compensating for? For example, Reichert made other microscopes: Neozet, Biozet, Microstar, Jung, Polylite and others. How do I know that an ocular I am buying compensates for the objectives I have? Is it the case that Reichert was consistent with its compensating design so any Reichert ocular I buy will be OK?
4) I have read several articles on Kohler illumination but none of these articles have two-diaphram condensers. What are the two diaphrams on my condenser for?
5) Reichert made two different kinds of phase contrast systems: Zernike and "Anoptral". I know from the catalogue that my objectives are anoptral phase contrast. I am interested in buying a condenser to do phase contrast microscopy. In the catalogue there is only one kind of phase contrast condenser listed and it says "Phase/Anoptral phase contrast condenser". Does this mean that the condenser works with either kind of phase objective?
6) The microscope came with an incomplete illumination system which is the "US" system on page 9 of the catalogue. It has two filter slides but one filter is missing. I think I am missing the "frosted daylight filter". With the LED retrofit illumination system will I need this filter?
7) can I use the phase contrast objectives for standard brightfield microscopy?
8) on the 100x objective what is the purpose of the iris?
9) I am imagining that it may be hard to find an Reichert compensating ocular that has a reticle. If I can't find one of these, are there other ways of doing measurements through the microscope?
10) other than eBay, what are some good places to look for Reichert parts to buy?
thanks
brett
