Chris S. wrote:William G,
As ChrisR said, welcome to the forum!
So that we could better understand the Wemacro rail, could you perhaps share the following specifications?
- 1) What is the thread pitch of your linear actuator's lead screw? (For example, 20 threads per millimeter, etc.)
2) How many full steps per revolution does your stepper motor have? (This can also be expressed as degrees per step) [(For example, 200 steps per revolution (1.8 degrees per step), or 400 steps per revolution (0.9 degrees per step)]
3) Your controller appears to offer micro-stepping. How many micro-steps are there for each full motor step?
4) Further regarding your stepper motor, is it bipolar or unipolar? How many phases? How many wires? What is its NEMA size? (I ask these questions, because knowing the answers would aid potential customers in sourcing additional stepper motors that would work with your controller, but on their own hardware--such as a microscope.)
5) For these same potential customers who might wish to use a different stepper motor, does your controller permit the user to adjust things like motor torque, motor speed, and ramp time?
Cheers!
Thanks Chris S! I hope these answers can help.
1) The thread pitch is 1mm.
2) The step motor has 200 steps per revolution(1.8 degrees per step)
3) Each full motor step means 1000micron/200=5 micron the rail will move.It contains 5/0.3125=16 micro steps.
4)The motor is bipolar which has 2 phase and 4 wires.I had upload a picture to show the
connection part.NEMA size is 17.But we suggest user to use our motor to make their own hardware.We will supply the motor later on website with plug which is easy to connect and solid.
5)Sorry for this question,users can not adjust motor torque, motor speed, and ramp time.
