Small metal knobs for manual stages
I'm having no luck finding small metal knobs for replacing some knobs on several goniometers and XYZ stages which have belt gears. I want to use these stages manually, not with a belt-driven pulley system. I think most of these are 3mm shaft but some may be larger or smaller. Where can I find small metal knobs for round shafts with dual set screw locks? I've tried looking around in various places but so far no luck. Any advice?
search for potentiometer knob
http://uk.rs-online.com/web/p/potentiom ... s/7830189/
P.S.: did the Labophot gear arrive?
A couple of my goniometers came with timing belt pulleys already mounted. They looked a little funky but functioned fine as knobs, so I just left them.
Alternatively, you might consider 0.200" = 5.08 mm, for example DigiKey's https://www.digikey.com/products/en/har ... d=&pv73=52 .
This seems to be more what you're looking for:
https://www.mcmaster.com/#machine-compo ... s/=18t6pka
The hole is unthreaded and it includes a set screw.
For Dean's knob,
You probably know K&S brass tube:
https://www.alwayshobbies.com/materials ... brass-tube
The quarter inch size is a close slide over 5.57mm
Slit longitudinally it may be ok to use on 5mm shaft?
