Zernike was the inventor of phase contrast and Nomarski the inventor of Differencial Interference Contrast (DIC). Both worked with Zeiss to produce the first commercial models.
Check the Wiki.
Their names were sometimes used to refer to that systems, and sometimes avoided, maybe to avoid paying for the patents.
Zeiss named their 160 models Inko from Interferenz Kontrast, Leitz ICT, Olympus NIC...The wording DIC is more common in modern systems.
There are also variants of that systems sometimes named after their inventors. The names of Zernike and Nomarski are sometimes used to refer to the original desing and differenciate them from the variants.
Vintage Zeiss Primer?
Here is a link to some leaflets/brochures on the 4 different types of DIC for the Zeiss 160 tube microscopes.
http://www.microbehunter.com/microscopy ... 766#p11766
Zeiss Standard WL & Wild M8
Olympus E-p2 (Micro Four Thirds Camera)
Congratulations!
Correct position is viewed from the right side of the condenser where they line up with a vertical mark.
Have you rotated it through all the positions? It is sometimes easier to view from underneath.
http://www.microscopy-uk.org.uk/mag/art ... denser.pdf
There should be a phase annulus at position I, II and III.The condenser is strange: there is no contrat PH filter
That is not the right type of condenser for that. See image of 3rd condenser in Fig. 1 in the pdfNot sure if there are any Wollaston prism as well.
Try https://en.wikipedia.org/wiki/Phase-contrast_microscopy and https://en.wikipedia.org/wiki/Different ... microscopy .KurtM wrote:I have often heard the names Zernicke and Nomarski associated with DIC, and I think phase contrast too? Could one of you could give a brief explanation of what/who they are and/or what it means to us, or point me somewhere for same?
