Jack,
I use the PB-6 with D800 and D500 without any extensions required. As mentioned by Chris, you just rotate the camera end of the PB-6 to install/uninstall the camera. I would think the D810 should fit as well.
I have a D500 with the PB-6 with Raynox/Mit sitting on a WeMacro focus rail being controlled by Zerene without spacers. I'm utilizing the Stackshot controller and a motor interface cable I built to go between the Stackshot controller and WeMacro rail. All plays together nicely.
New Bellows - Dust, filters, Adapters Questions
- JohnKoerner
mawyatt wrote:Jack,
Hi Mike;
As I said in my message, it worked on my D810 also ... but only after I pulled off my RRS L-bracket ...
Cheers,
Jack
PS: You and I shoot the same two cameras: D810 and D500
My guess is over-tightening.austrokiwi1 wrote: . . . I have a Minolta Auto Bellows III, Tilt shift version. A few things I have learnt. the "bushes"( is that the right term?). that slide over the bellows rail seem very prone to cracking. I am not sure if it is age related or a design/operator error combination.
You can see similar cracks on several PB-6 currently on eBay:
162246689447, 142158771960 (PB-6E), 232111405584 (PB-6 slide copier)
Here's a thread on repairing them if a crack starts to interfere with use, (In this case a Canon FD Auto Bellows and an Olympus OM Auto):
http://www.photomacrography.net/forum/v ... ows+repair
-Gene
