Insect examination/posing/microscope stages
JohnyM
Post by JohnyM »
Just check ebay once in a while. I've Paid ~30USD / per japan made goniometer. Take care to match nodal points.
NikonUser
Re: goniometers
Post by NikonUser »
Yawns wrote:
not everybody can afford them ... it's not a question of lack of knowledge .. it's a question of budget and income... when you don't have the resources gotta be creative and turn around the situations ...
I was just trying to be helpful, with luck you can find small ones for <$50.00
NU.
student of entomology
Oliver Wendell Holmes, Sr
JohnyM wrote:Just check ebay once in a while. I've Paid ~30USD / per japan made goniometer. Take care to match nodal points.
So have I - this was even less:
viktor j nilsson
Post by viktor j nilsson »
That looks... rough. Does it work well?
Saul
Post by Saul »
My setup (thanks Charles for the great idea). Only difference - I'm using soft ball needle instead the copper strip.. Before I tried micro stages, had a " rotatable goniometer" - small thing from the Stanley SU-100 door sensor, which holds/positions micro antenna inside the unit (was pretty comfortable).
But slide/clay/needle combination was the winner - very compact, easy to place around different diffusers, you can have n+1 ready specimens if you think, that you photo session is not fully complete yet, etc ...
viktor j nilsson wrote:That looks... rough. Does it work well?
:lol: It's a bit small, but yes it works! It's nickel plated so less sexy than most. It needs a square-bore tool to adjust - I made one from a brass tube. It has a better tilt range than most goniometers, but of course a short radius. The dark screw holes you can see adjust the stiffness of the slides. It's very solid.
Later a forum member sent me a base for it which gives 2 more degrees of freedom, making 5.
I believe it's designed for crystallographic measurements.
Len Willan
Post by Len Willan »
A Simple Horizontal Rig for Pinned Insects
Posted: Tue Dec 08, 2009
Its pivoting “Stick Pin Sleeve”was made from a cheap kitchen cupboard spring loaded Ball Catch ,which has been drilled to accept a tube from a hypodermic needle.
This provides for both the adjusting of a “set” specimen to the horizontal plane and to rotate and tilt to the vertical. This can be done with your left hand when sitting at the bench looking through the viewfinder, it also allows ample tilting to one side so that specimens can be removed with ease and safety
The “Stick Pin Tubes” of various lengths are the next larger gauge of hypodermic needle secured by a soldered off cut of the locking screw of a camera cable release.
Pins of all sizes can be safely pushed into the wad of Bergeon Rodico that has been inserted into the open end of the tube, and when the Rodico is spent it can easily be removed with a small twist drill.
JohnyM
Post by JohnyM »
Very nice stage Chris! Looks like one fancy "CSI" bullet comparision stages?
I've purchased "classic" goniometers. 60x60 with 80mm WD and 40x40x20 with 60mm WD for 35 and 25 USD respectively. Those are amazing tools, i cant imagine how i've managed to take stacks without those now :)
Yawns
Post by Yawns »
sometime ago I found this company based in Europe (Lithuania) .. so free of import taxes for europeans
Eskma Optics... their prices are far more reasonable than Thorlabs or Edmunds... if if their stuff is good .. I don't know
http://eksmaoptics.com
190€
Deanimator
Re: goniometers
Post by Deanimator »
Yawns wrote:
NikonUser wrote:I guess all the above work, but if you wish to get better control over your bugs then a pair of goniometers is essential (see AnrewC comment)
http://www.photomacrography.net/forum/v ... goniometer
I know what you mean.
When I was working crappy contract IT jobs, I learned a LOT about making stuff with PVC pipe.
Stolen from another forum:
Poundland, £2
https://m.youtube.com/watch?v=k8tdA07ERRI
lothman
Post by lothman »
tcnr
Re: Insect examination/posing/microscope stages
Post by tcnr »
First post, so apologies!
I use 2 types of stage. Very pleased with the 'EntoBall' from https://www.microscopesplus.co.uk/page143.html and the Lego Open-IMp described here https://zookeys.pensoft.net/article/4667/
The Lego was tremendous fun to build but it took over an hour to order all the parts!
