SEE ALSO: http://www.photomacrography.net/forum/v ... 154#133154
Examples of convergent evolution.
Homo sapiens has developed the Hypodermic Needle, a fine sharply-pointed tube with an opening at the tip:
Top: 27 gauge needle
This can be seen as a design flaw in that the tip has been weakened by having almost all of the wall ground away. But as it is designed for one-time-use only such weakness is moot.
In nature’s hypodermics the tip remains intact and the opening is placed further back along the ‘needle’. Needle always seems to be curved.
Three of these animals use a modified mouth part as the hypodermic, the centipede uses a modified leg.
I would like to see the structure of a scorpion’s sting.
Rattlesnake, tabanid (predaceous fly) larva, spider, stone centipede.
NU13-02-06-1-5
Nature's Hypodermics - image added Feb 8
NU.
student of entomology
Oliver Wendell Holmes, Sr
- Charles Krebs
Thanks for posting! Very interesting indeed.
lAlways look at how nature solve things...
Fred
Canonian@Flickr
Canonian@Flickr
Ah! But there is one difference, the stinging insect etc, has no problem about causing pain to a victim; whereas the hyperdermic needle is designed to cause the least pain possible....
SORRY......SHARP SCRATCH ;-)
Sonyalpha
Sonyalpha
Retired but not old in spirit:
Fairly new to photography........keen to learn:
Thanks everyone.
Chris ... an ant stinger is a totally different design. The stinger is a modified ovipositor and therefor present only in females. Always a single unit made up of opposing appendages; no permanent canal but but a temporary one formed by the apposition of appendages. Entrance into the victim is by the alternate thrusting of two barbed lancets. Poison flows between them and a dorsal stylet into the wound. Certainly would make a much larger wound, with torn flesh, than the hypodermic type.
NU.
Excellent pictures, NU, and a nice variety of subjects!
If that's correct, then Wikipedia also has an SEM picture HERE. I'm not sure about that page's explanation of the "bulbous sheath", however. That looks to me like possibly a drop of dried venom, similar to what's in my image HERE and which quickly dissolved in alcohol to produce the better picture HERE
Sounds like a velvet ant, actually a wingless wasp. Wikipedia notes that "They are known for their extremely painful stings, hence the common name cow killer or cow ant." Really not much mechanical damage, but nasty toxins!Chris S. wrote:bright red ant ... imagine it looks like a stick of dynamite.
Just found a man-made' hypodermic' that mimics the design of Nature.
It's an "Air pressure cork remover", pierce a wine bottle cork and pump air between the cork and the wine, cork pops off. And yes, it works!
Note how the pointed tip is of a different metal than the tube and how the tip is being damaged but the exit hole is staying intact.
NU13-02-08-1
NU13-02-08-1
NU.
