www.photomacrography.net :: View topic - Mounting small bugs
Mounting small bugs
NikonUser
PostPosted: Thu Sep 06, 2012 6:38 am    Post subject: Mounting small bugs Reply with quote
I use standard entomological (insect) pins to hold insects for photography. These pins are a standard length of about 37 mm and come in several diameters, labeled as 000 , 00, 0,.........7.
for larger insects, length >15 mm, simply sticking the pin in the insect will hold the insect firmly.
For small insects one needs a small diam pin. However, such fine pins will not hold the insect firmly, a tendency for the insect to rotate on the pin. Large pins will hold but will often damage the bug.
Solution: glue 2 minuten pins onto a fine regular insect pin and use the resulting prong to securely hold tiny insects (on the side opposite to the one to be photographed) without damage:
Here is the image with this set-up:
NU.
student of entomology
Oliver Wendell Holmes, Sr
dissent
PostPosted: Thu Dec 06, 2012 12:11 pm    Post subject: Reply with quote
Neat idea. Thanks.
Bug macro - I'm finding out it's not just about camera, lens and how to point it.
- Ian
"Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities. Truth isn't." - Mark Twain
