Ok here's stack #2. All in all, from beginning of the shoot to now, it has taken something like 8 hours of work. Long story short I bumped the setup ruining the stack so i had to start over, my batteries died in both my camera and my flashes so I had to wait for everything to charge mid-stack, stacking takes what has to be close to an hour since my laptop is so slow.... which I had to do three times because I tried to figure out how to make the hairs not have those odd artifacts which i could not undo so I had to start over again each time, and because finally when I had everything ok the computer froze and did not start to work again for another hour or so
UGH
SO, here's the final result. All in all, very minimal PP just cropping, rotating, RAW to jpeg conversion, and some curves.
Phidippus Audax by yeatzee (now 17, but still learning), on Flickr
60 images stacked. The setup was a Pentax F 135mm F/2.8 with a reversed Pentax F 28mm F/2.8 stacked. The 135mm was wideopen and the 28mm was at I believe F/4. 3 second shutter speed, MLU, two flashes with their own respective diffusers, ISO 100.
What do you think of this one?
edit: some crops
Got my linear stage :D the obligatory test shot....
Ha! Next time what color would you suggestChrisR wrote:Lookin good, very good!
But would you do it all again please, because I don't like pink-orange-yellow-green backgrounds ?
Thanks Javier!seta666 wrote:This second stack looks perfect to me, wonderfull lighting, beautiful background; everything in place
As I said when you first posted in this forums "you will retire us all" ;-)
Regards
Javier
Thank you ChrisChris S. wrote:Yep, looks great! Nice job with the lighting, background, and all else.
As Rik said, it gets easier. I sure have been there myself.
Cheers,
--Chris
Thanks Rik. Worth it in the end for sure... especially when viewing it on my friends MASSIVE apple desktoprjlittlefield wrote:Excellent! Great capture of fine surface detail, no blown highlights, no unnecessary dark shadows, attractive background color.
Having gone through just what you describe, I feel your pain. Trust me, it gets better.
Graham46 wrote:Great job
Thanks
