www.photomacrography.net :: View topic - Photomicrography set-up with DSLR...Charles Krebs
twebster
PostPosted: Fri Jul 28, 2006 8:30 am    Post subject: Photomicrography set-up with DSLR...Charles Krebs Reply with quote
Submitted by Charles Krebs...
Here's a picture of how I have set my scopes up to do photomicrography with a digital SLR (Canon 10D). It's pretty near identical to the way it's been done for years with film SLR's. The camera is mounted on a stand above the microscope, with no physical contact between camera and microscope.
I've put together a "personal web page" that describes most of my set-up. It's still pretty basic, but has much more info than I could put in a message.
It can be accessed here:
http://www.krebsmicro.com/microsetup2/index.html
Admin edit, rjlittlefield, 2018 Dec 10, replaced broken link http://micropix.home.comcast.net/microsetup/index.html .
Biologyben
PostPosted: Mon Sep 25, 2006 10:42 pm    Post subject: Great setup Reply with quote
This is awesome! The bellows solution is so much more simple and flexible than the interesting assembly of pvc tubes i rigged up a few years ago when when i mounted a really old canon ftql to a 1960's scope (at least it matched the age of the camera). But, i didn't have access to any plan objectives, was using no flash. Ended up being something like a 20 second exposure...it was interesting and fun tho.
Anyway ... I've got most of these parts laying around and am looking to buy a Canon 350d sometime...
A few questions. Any instructions on making the variable controller for the Vivitar? How about the mouse/remote release?
Lemme know!
Ben Shuman
rockdoctor
PostPosted: Mon Apr 23, 2012 3:56 pm    Post subject: It's InKrebulous Reply with quote
Drool!
This is my very first post since joining. And I want to thank you Charles for replying to some of my questions off site. I'm still searching for your recommendations on objectives. I'm gathering equipment terminally slowly but it does take time. So far I have been shooting with a Nikon D3100 & Nikor 60mm AF-S ED Macro with very nice results. I recently picked up a Canon Rebel T3i which I attached to my old trusty Zeiss DRC stereo scope. Wow! what a breeze it is using the EOS utility. My first stack from Zerenne was a very good quality picture given my inexperience, but Zerenne makes it pretty easy even for a newbie.
On the lead of someone from this forum I shopped for and found a nice Z-axis stage with 3mm of vertical travel using a micrometer that moves the stage microns at a time, I believe one rotation of the micrometer is 50 microns. Haven't got it in yet. Check Ebay here:
http://www.ebay.com/itm/110662903009?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
He has 4 more, I bid him down to $130, I think he might go lower. This will work well with my stereo scope base since I shoot pics of teeny tiny rock chips that never move. Still can't wait to find the right objective for sale!!
Cheers,
Doug
Quote:
Innovation usually comes from individuals dissatisfied with the status quo.
yanyading
PostPosted: Mon May 14, 2012 6:00 am    Post subject: Reply with quote
Sirs, here is my solution, I use fixed stuff instead of bellows.
Flickr 上 yanyadingOlympus CH-2 Microscope with Tube (Projective Eyepiece Inside), Canon 350D and Angle Viewfinder.
The result is also good.
Flickr 上 yanyading班氏丝虫微丝蚴
Shot with Zeiss Neoflour 63X NA1.25 + 3.3X photo eyepiece
UV is the Key to High Resolution Microscopy
FrancisCC
PostPosted: Tue Oct 13, 2015 12:18 am    Post subject: Reply with quote
Nice set up. Are you using the bellows to achieve greater magnification or merely to replace a lens system between the phototube and camera to have the image correctly on the sensor? I use a diagnostic instruments system.
Being resourceful is the key
View user's profile Send private message AIM Address
FrancisCC
PostPosted: Tue Oct 13, 2015 12:22 am    Post subject: Reply with quote
Flickr ? yanyading ? Olympus CH-2 Microscope with Tube (Projective Eyepiece Inside), Canon 350D and Angle Viewfinder.
Flickr ? yanyading ? [url=http://www.flickr.com/photos/644000/7029300123/]???????[/url]
That Zeiss Neofluor 63 is a great lens, I almost exclusively used it for several years research work. But I didn't own it LOL!
SutherlandDesmids
PostPosted: Sun Dec 09, 2018 2:51 pm    Post subject: Reply with quote
Unfortunately the description does not seem to be working.
I have emailed Mr. Krebs, but I thought it might be useful to warn that I at least can't get it to work (Compaq 610, Mozilla Firefox).
Although quite elaborate and likely far beyond me, the setup seems an excellent idea and well worth studying in detail. I presume a great advantage gained by uncoupling camera and microscope is that vibration becomes a nil issue.
Patrick J.K.C. Gray
Alan Wood
PostPosted: Sun Dec 09, 2018 4:47 pm    Post subject: Reply with quote
Patrick
Charles Krebs now has his own website:
An updated version of the missing page is here:
Alan Wood
PostPosted: Sun Dec 09, 2018 5:03 pm    Post subject: Reply with quote
Thanks for the update, Alan. I've admin-edited the original post to provide that new URL.
