When I try to do an attachment in a post and add the file, I only get the option to delete the file, not to place it in line.
Can't add images
Can't add images
Re: Can't add images
This is very puzzling, and the first such report that I've heard. At this moment I have no idea what's going wrong.
Can you do an image capture of your screen at a point where the inline option should be showing but isn't, and post that screen image for us to look at?
If I can't add an image, I am not able to post a screen shot. Also, I double-checked the image size and it is all within spec.
New test image.
You described the problem with these words: "When I try to do an attachment in a post and add the file, I only get the option to delete the file, not to place it in line."Olympusman wrote: ↑Sat Jul 25, 2020 1:10 pmIf I can't add an image, I am not able to post a screen shot.
I read that as saying that you were able to add the file (because you had the option to delete it), but did not have the option to place in line.
So now I'm very confused. What exactly are the symptoms?
If the problem is repeatable with some particular file, then please send me a copy of that file by email to rj.littlefield@computer.org and I'll see if I can reproduce & debug it on my end.Olympusman wrote: ↑Sat Jul 25, 2020 1:22 pmI just tried it with another image and it worked. There is something about the other file the program doesn't like.
